Please could someone advise& explain whts going on with magenta print out issue
  • hsh6049
    • Jul 2012
    • 64
    hi
    i am really appreciated someone could advise with print test pattern 30 % a lot of straight line is it due on magenta developer tank
    first , reading 0 when enter atc sensor setup, correction offset only the magenta reading is 0 , the barcode number is correct (picture 1)
    second while print out test pattern with 30 % there was a lot straight line
    third new set of ori drum, replace dv tank and developer still same porblems
    please could advice wht can i do next
    thanks a lot
  • GIUBOSS
    • 1431
    Re: Please could someone advise& explain whts going on with magenta print out issue
    Originally posted by hsh6049
    hi
    thanks a lot
    try cleaning the optics section and the laser section
    • shinchan
      • May 2011
      • 195
      hi
      thanks a lot
      my guess with the machine model, is docucentre C2200 C3300?
      original developer ? new / used?
      original developing unit? new / used?
      white lines usually LPH is shot or something is blocking in the developing unit area.
      • hsh6049
        • Jul 2012
        • 64
        yes i did clean optics for the laser clean the laser my color machine model c6500
        • hsh6049
          • Jul 2012
          • 64
          apeosport iii c6500 new dv tank new ori dveloper i did clean the glass inside the laser my
          • hsh6049
            • Jul 2012
            • 64
            Originally posted by terramobil
            It would help if we know which device you are talking about.
            apeosport iii c6500
            • shinchan
              • May 2011
              • 195
              have you try printing 30% tone with black, cyan and yellow?
              any white lines?
              • hsh6049
                • Jul 2012
                • 64
                any white lines?
                yes even test yellow no issue only magenta is not only white line will print out magenta it like something wrong with magenta , even replace new drum unit magenta developer and tank also same problem
                could be laser or could contact point dvtank to back side?
                • shinchan
                  • May 2011
                  • 195
                  can you swap laser magenta with laser cyan / yellow /black?
                  then try print 30% half tone again. see whether the problem change to the other color.
                  if changed, that means the laser is shot
                  • hsh6049
                    • Jul 2012
                    • 64
                    owh ya noted with thanks
                    • hsh6049
                      • Jul 2012
                      • 64
                      against each laser flat cable can be exchange ?
