Can't print on Workcentre 7125 (pagepack)
  • mousse60
    • Jun 2022
    • 12
    I've a problem with my workcentre 7125 bought used since more 2 years. When I've purchased it, i doesn't know there is a pagepak with it .. and this pagepack is now expired ..
    I don't need pagepack, so someone could you please help me to reconfigure this printer to sold printer ? (serial 3326231320 ).
    I'm very bored, I have some documents to print, and I don't..
    Many thanks by advance.
  • koombaya
    • Jun 2022
    • 8
    Re: Can't print on Workcentre 7125 (pagepack)
    Hello, did you solve your problem ?
    • mousse60
      • Jun 2022
      • 12
      Hi, no, always the same problem :-(
      I've updated firmware and change the HDD, but, the pb is always on :-(
      • koombaya
        • Jun 2022
        • 8
        I found a code generator on the web, but it gives a code with 8 numbers (only numbers, not any letters, bas length), so it doesn't seem to be the good one...
        I generated a code with your S/N if you want to try : 18364248
        I'm crossing my fingers
        • mousse60
          • Jun 2022
          • 12
          Many thanks for your support, but it doesn't work :-(
          I can enter only 6 characters.
          • koombaya
            • Jun 2022
            • 8
            Damn... i'll let you know if i find the good tool.
            I think the one i got is for old black and white machines.
            • mousse60
              • Jun 2022
              • 12
              OK, many thanks. I hope you can found it :-)
              • GIUBOSS
                • 1437
                try replacing the toners, they probably have run out of service life with the package
                • mousse60
                  • Jun 2022
                  • 12
                  Do you think, I can test with by buying one toner and see if he is desactivate, or I sould buy the 4 toners ?
                  • GIUBOSS
                    • 1437
                    I asked a colleague, I have not tried it myself, it is for a WC 3655i which indicates to me '' all the courtesy pages have been used .... '', I have put the toner in order and I can let you know
                    • mousse60
                      • Jun 2022
                      • 12
                      I've changed all 4 toner, and always the same ...
                      After, I've changed chip of toner, and always the same ...
                      I can't print on my printer.
                      It's very frustrating issue ..
                      • Jack79
                        • Jul 2014
                        • 312
                        Try this. Insert 4 SOLD toners and close front door. Turn the printer off (both switches). Turn the printer on.
                        • mousse60
                          • Jun 2022
                          • 12
                          I've do this, but, Magenta toner is on error.
                          I've change Magenta Druml too, I've to change Cyan Drum.
                          No, i've an error 10-333, I've change the fuser, but always error ..
                          • mousse60
                            • Jun 2022
                            • 12
                            • mousse60
                              • Jun 2022
                              • 12
                              [ATTACH=CONFIG]56730[/ATTACH]
