Error on Fiery Xerox C70 : (
  • sistecopy
    • Jun 2022
    • 6
    [Dead] Error on Fiery Xerox C70 : (
    Hi..
    I have a problem with fiery on EX-i C60/C70.
    The fiery doesn't start up... i download ISO file and EFI USB tool to restore the SW on FIery...but the usb donnt boot... always get the same on the monitor.
    I upload image of my problem...
    Appreciate any help to resolve this....
    thanks
  • xcopytech
    • Aug 2006
    • 1786
    Re: Error on Fiery Xerox C70 : (
    What you have on small led display
    • sistecopy
      • Jun 2022
      • 6
      appears "00".
      • jhalfhide
        • Apr 2015
        • 451
        00 indicates it has booted to ready. When you say it wouldn't take the USB, did you set the dip switches correctly?
        What's the actual symptom for you to say it isn't booting? Is the fiery icon on the Xerox display? Is the fiery appearing in command workstation on the network?
        Sent from my LYA-L09 using Tapatalk
        • xcopytech
          • Aug 2006
          • 1786
          If you have good SW on usb and if you set dip switches as in service manual small led should start to counting and when upload is finished fiery should power off
          • jhalfhide
            • Apr 2015
            • 451
            And then when you set the dip switches to normal and turn it back on, just walk away... Go out and have a coffee. So many times people (myself included), think it's taking too long and hasn't worked. Be patient. I've seen them take a good 20-30 minutes before that startup page comes out
            • Caffeine
              • 389
              Originally posted by sistecopy
              appears "00".
              That's what it is supposed to say. The text "Booting the kernel." is the final thing the Fiery outputs to the video port. On the embedded (bustled) Fierys, you will never see anything on the monitor after that, nothing is wrong. They aren't designed to have monitors attached to them. Only the standalone Fierys are.
              • sistecopy
                • Jun 2022
                • 6
                Lol... i take the good coffe, also breakfast an lunch to... but nothing happend...
                I get same about booting kernel, and there is no icons of fiery in the C70... i leaving for more of 2 hours..
                Any idea? i follow the steps of the procedure to make the USB to install the system, but doesn't boot..
                • jhalfhide
                  • Apr 2015
                  • 451
                  Ignore the monitor. Disconnect it from.the fiery. Make the usb and set dip switch 1 to ON. Insert usb and turn on fiery. Watch the screen on the fiery and it will start counting C1, C2, C3 and loop. When it powers off, remove the usb and pop the no1 dip switch back up. Then connect the cables to the machine and boot the fiery. Ensure machine is on DHCP.
                  • adriansto
                    • 2377
                    What is the serial number of the Fiery ?
                    • sistecopy
                      • Jun 2022
                      • 6
                      Originally posted by adriansto
                      what is the serial number of the fiery ?
                      p/n: 45148166 s/n: R00299261
                      • xcopytech
                        • Aug 2006
                        • 1786
                        According to pn that is bustled e300 fiery?
                        What software version you have?
                        • sistecopy
                          • Jun 2022
                          • 6
                          The original version that comes with the fiery was v1.10.. I download the v2.1 from xerox site..but i can not installed on the fiery..
                          • xcopytech
                            • Aug 2006
                            • 1786
                            Do you have User software iso file too
                            • jhalfhide
                              • Apr 2015
                              • 451
                              I think I remember reading somewhere that you must use the same version you had, and cannot use version 2 software if you had version 1.
