error code 006-380
  • newtech
    • Mar 2009
    • 13
    error code 006-380
    hi all ,may i know if anyone happen to know what does the error code 006-380 means for Xerox DCC 240 model? thks
  • xcopytech
    • Aug 2006
    • 1792
    6-380 ROS SOS Y Length
    The interval of the ROS Start-of-Scan (Y) signals exceeds the specified value.
    • newtech
      • Mar 2009
      • 13
      enquiry
      Hi , so how do I troubleshoot this?
      • copytech200X
        • 264
        chk ros connector to mcu pwb ..is it happen after replacement developer assy?
        • TechMate
          • Mar 2008
          • 285
          Check the condition of the wires from ROS to MCU PWB. If theres no open circuit and the problem still continues, replace the ROS and if problem still continues, replace the MCU.
          In most cases that i've come across, i've replaced the ROS and the MCU at the same time. a xerox tech would be preferred to fix this problem
          • newtech
            • Mar 2009
            • 13
            thks
            ok ., thanks for the information. I will try as advised.
