Xerox C70 duplex jamming
  • buzz
    • Aug 2013
    • 288
    30 yrs in the business, .0009 yrs servicing xerox, lol.
    Customer has two C70 copiers. Both are jamming when duplexing, maybe 1 out of 10 pages. I told them to turn the paper orientation from portrait to landscape to see if it makes a difference and will call me back.
    Looking to go on site for these machines, what should I be checking?
    Thank you!
  • xcopytech
    • Aug 2006
    • 1794
    Re: Xerox C70 duplex jamming
    First get fault code when machine declare paper jam so you can check it in service manual.
    • xeroxbg
      • Feb 2020
      • 10
      There was such a problem three years ago with the Xerox C75.The cause turned out to be a loose belt on the duplex.Try adjusting the duplex belt.
      • Detonation
        • Feb 2010
        • 410
        In my experience often the inverter solenoid, but it depends on where the paper jams.
        • Tech-Yeah
          • Nov 2022
          • 8
          Drag in the duplex transport system can cause intermittent jams. The brass bushings and the drive shafts will need to be cleaned. Preferably, replace the brass bushings with ball bearing ones.
