Xerox WC7830 Problem
  • eng_usama
    • 115
    hello guys problem with Xerox wc7830 the scan always have cyan background all over the page what we can do for it guys?
  • Jack79
    • Jul 2014
    • 312
    Re: Xerox WC7830 Problem
    Try suppression on for scanning.
    • eng_usama
      • 115
      Thanks for your answer I did it and no difference any suggestions?
      Thanks in advance
      • Jack79
        • Jul 2014
        • 312
        Thanks in advance
        From my experience scan with cyan background was resolved by changing suppression or set lighter up +1 +2.
        Have you check if copies are also affected?. Try scan from adf and glass to see if there is any difference. Are you scanning duplex? If your copies are also affected or just one side then it can be faulty small board I think they call it pyxis board but that was for copy not only scan problems
        • big mike
          • Sep 2012
          • 155
          Did you try swapping the cyan drum with yellow? If it changes, it's the drum.
          • Jack79
            • Jul 2014
            • 312
            But he said he got issue with scan not copy.
