Versant 80 124-374
+ More Options
Posts
  • big mike
    • Sep 2012
    • 144
    Versant 80 124-374
    I get fault code 124-374 when I power up the Versant 80. The pws refers to a business ready finisher, and I have the advanced production finisher with the booklet maker (TKX). I powered it off and on, unplugged and plugged the power to the finisher. No luck. Like previous models, will it run without an interface and finisher? Any advice will be appreciated.
  • xcopytech
    • Aug 2006
    • 1792
    Re: Versant 80 124-374
    V80 can work without interface and finisher.
    124-374 can be something with ESS PWB
    • adriansto
      • 2384
      Read the bulletin nr. 1413376.
      What printer software level?
      • big mike
        • Sep 2012
        • 144
        Thanks, I will see what happens after I disconnect it.
        • big mike
          • Sep 2012
          • 144
          I don't think I have the bulletins but will do a search for that number. I have all the RAPS and Searchlite. I will let you know what level s/w Monday.
          Actually, it was working fine. I used parts from this V80 to test on another one. I reinstalled the MCU, both AC power modules and both LVPS. There were lots of plugs and screws. I took my time, took lots of pictures, didn't have any extra ones but perhaps one is not seated all the way. There's a good chance that's what I will find.
          • adriansto
            • 2384
            You'll find the bulletin in SearchLite. First machine software versions have some bugs..
            Will be nice to load more recent version.
            • big mike
              • Sep 2012
              • 144
              Found it, I'll try it. You are the best.
              • big mike
                • Sep 2012
                • 144
                I reloaded the s/w, it came up after that. Thanks!
