Versant 80 Problems with Cyan, but no Error Codes. Mistery?
  • alextech
    • Apr 2023
    • 24
    Hi community
    Here it is, my first Post. And my first time i dont find the Problem in time.
    Found here solutions for many problems and it saved me a lot of time. Thanks to all for there contribution.
    I have a Versant 80 here, where the Cyan is not printing correctly.
    What i already did:
    - Swapped Drums (Yellow->Cyan)
    - Replaced the Developer Housing (Took from one that had to be replaced, Printing Quality there was around 85%, but printed cyan very well)
    - Cleaned out the 2nd BTR (Had to clean it anyway...)
    - Componenttest on Drum motor (It sounds at least..)
    There are no strange noises or a lot of cyan toner around...
    Usually the boxes just throw error codes around, but in this case there is no error code, which is also very strange.
    When I disassembled the machine for the first time, I found a scraped off drum on Cyan and the missing drumsurface was on the Developer magnetic roller.
    But now that everything is replaced (drum and developer housing) I am a bit desperate.
    Before I now disassemble everything and go for the motors, I wanted to share my results, maybe someone already knows such a picture and can save me a lot of time
    Thanks!
    Alex
    Here how the Testprint looks:
    (Notice exactly where should be Color its white...)
    Here how it SHOULD look:
    Here how the Full Chart looks:
  • zart20
    • Feb 2023
    • 3
    Hello everyone, and I have the same problem. Is there a solution?
    • Detonation
      • Feb 2010
      • 403
      I don't know this problem, but would check 1st BTR of cyan of dev bias HVPS
