Xerox Workcenter 3220 scaner reads nothing after repairing broken line on cable ribbo
  • HOSTAKI
    • May 2019
    • 23
    [Electrical] Xerox Workcenter 3220 scaner reads nothing after repairing broken line on cable ribbo
    continuity tests where done while I had the scanner moving manualy, to check if repair was done properly or it was anywhere miissing a bit as before.
    No mixed lines or anything .
    If I totaly unplug the cable and try to scan I get a completely black printout.
    I will also try to insulate the repair in case of short circuit somehow .. ? If that is the problem ?
  • GIUBOSS
    • 1433
    Re: Xerox Workcenter 3220 scaner reads nothing after repairing broken line on cable r
    Did you fix the flat cable or replace it... as it should be
    • HOSTAKI
      • May 2019
      • 23
      I think its clear that I fixed it and did continuity tests, as I cannot get a replacement somewhere
      • GIUBOSS
        • 1433
        There may be micro breaks sensitive to some movements that are so difficult to measure.
