Help with Xerox WC7830
  • eng_usama
    • 115
    Hello guys machines printing with good quality
    But when copying it is very bad as photo attached I tried change scanner unit
    Software update change mcu nothing change same copying as attached.
    Any idea to help
    Thanks in advance
  • GIUBOSS
    • 1436
    Re: Help with Xerox WC7830
    Update Spar software to latest ver.
    , perform white reference adjustment using paper with brightness of 98% or higher as written in the manual.
    Reseat the ribbon cable in the optics that goes between the CCD assembly and the IIT pwb. Or replace:
    1. Ribbon cable between CCD and IIT.
    2. CCD assembly.
    3. IIT PCB.
