Xerox Color C60 - 077-304 Fault Code
  • standardprint
    • Sep 2023
    • 7
    [Error Code] Xerox Color C60 - 077-304 Fault Code
    I'm very new to Xerox machines and I'm having a really hard time diagnosing this issue. Fault 077-304 comes up as BSD-ON:2.1 IOT Interlock Switching BSD - Tray 5/Bypass Cover Interlock is open. When it's actually closed and locked the fault is still present but the machine starts to click (probably relays) repeatedly as if something is trying to move but is jammed. Opening the bypass tray stops the clicking but again, the fault is still present. I've looked everywhere and nothing is jamming the machine. When I first got it in and plugged it in, this didn't happen. I re-entered all the default NVM values that were tucked in the pocket in tray 1 and still no luck. Any help would be greatly appreciated!
  • standardprint
    • Sep 2023
    • 7
    Re: Xerox Color C60 - 077-304 Fault Code
    Update: Just installed a refurbished bypass try and the same fault code and symptoms are still present.
    • Detonation
      • Feb 2010
      • 410
      These problems often are caused by a bad door interlock. If you have access to one, try to change the one for the front door.
      • standardprint
        • Sep 2023
        • 7
        Another update: Even before replacing the front door interlock switch, the machine would not power on at all. No LEDs on the MCU at all. I changed both power supplies with brand new units from xerox, along with the new front door interlock switch and still nothing. I measured voltage coming in at 107-109 volts. I'm at a complete loss now..
        • Detonation
          • Feb 2010
          • 410
          MCU PWB would be the next logical candidate then.
          • standardprint
            • Sep 2023
            • 7
            I forgot to mention the MCU has been replaced by a new in box unit.
            • standardprint
              • Sep 2023
              • 7
              Does anyone have a schematic or wiring diagram? I'm measuring voltage coming in before the breaker, after the breaker, before the main power switch, and after the same power switch and all read normal. The logicboard/motherboard has 2 LEDs on so it's getting power. There are no LEDs on the MCU. Where could there be a loss or power or bad connection?
              • xcopytech
                • Aug 2006
                • 1794
                Service manual chapter 7.
                • standardprint
                  • Sep 2023
                  • 7
                  In case anyone has been following this dramatic saga, after many weeks of tinkering I have officially pronounced my C60 deceased. I have replaced it with an off-lease C70 so now I essentially have a full parts machine. Thanks to everyone who replied and messaged me with advice! <3 - Ethan
                  • Sasho
                    • Sep 2023
                    • 3
                    Problem:
                    M/c sat displaying 077-304 MSI cover open
                    When checking rap cc 077-305 is displayed as a invalid code
                    Cause:
                    Loose interface plug on printer to HCF feeder
                    Click on the Thumbs Up if this record helped you.
                    Click on the Thumbs Down if this record did not help you.
                    Remake interface conections/clean contacts.
                    Try this if its not too late.
                    cheers
                    • standardprint
                      • Sep 2023
                      • 7
                      Originally posted by Sasho
                      Problem:
                      Cause:
                      cheers
                      Thanks for the reply! Sadly the machine has already been disassembled and all parts catalogued.
