Thermal fuse for 260 fuser
  • big mike
    • Sep 2012
    • 150
    Does anyone know the temp and amps/specs for the reset fuses used when rebuilding the fusers for the 7775 family? I used the ones with a white end. Are the 162c or 182c? I can't read the micro print, it's worn off.
  • xcopytech
    • Aug 2006
    • 1794
    Re: Thermal fuse for 260 fuser
    You can use any between 85 and 105C
    • big mike
      • Sep 2012
      • 150
      Thanks, that helps.
      • nikolai.aleksie
        • Feb 2016
        • 177
        You can use a wire to connect both ends where the thermal fuse is placed, make a few copies, and then remove the wire to reset the fuser.
