Keep getting 077-130 / IOT Exit Sensor already replaced
  • alextech
    • Apr 2023
    • 24
    I keep getting the 077-130 on a Xerox 550 Machine. Printing is just fine unless the Paper turns around like for Duplex.
    Had first a bad Acctor inside the Inverter. Cleaned and fixed it, then. After then no more Jams, exept this one.
    I have replaced already the Sensor IOT Exit sensor 130K88400, but no Change. Paper goes intro Duplex and stops in the Middle after Sensor.
    Any Ideas? Maybe someone knows address to test the Sensor in Diagnostics. Unfortunately, I don't have the service manual for this box
    Alexander
  • xcopytech
    • Aug 2006
    • 1794
    Re: Keep getting 077-130 / IOT Exit Sensor already replaced
    77-130 duplex out sensor
    Does paper come in duplex?
    Check duplex motor and duplex drive belt, one way bearing gears
    • adriansto
      • 2387
      Alexander
      Read this post to the end:
      Xerox Color C60 - Error 077-118
      • alextech
        • Apr 2023
        • 24
        Okey. Disamble the whole thing and clean :-(
        I will give feedback when done
        Thx.
