Altalink C8170 Enter Current Password Message is Displayd at Start Up !!!
  • kropa
    • Jan 2024
    • 18
    [Dead] Altalink C8170 Enter Current Password Message is Displayd at Start Up !!!
    Устройство циклически перезагружается (по индикатору -У)
    после того, как требуемая прошивка запрашивает сразу ввод пароля, как на фото, при нажатии на кнопку питания перезагружается и снова запрашивает ввод пароля (дает 3 процедуры).
    Принудительно прошить еще раз не получилось, вставил новый жесткий диск.
    на индикаторе -6
    подключил внешнюю usb-клавиатуру и ввёл пароль 6789 1111 условие для установки лицензии.
    помогите кто с таким столкнулся, меня скоро убьют..... СПАСИБО!!!!!
  • Gaffers01
    • May 2011
    • 330
    Re: Altalink C8170 Enter Current Password Message is Displayd at Start Up !!!
    Can you attach a photo that is bigger ?
    • kropa
      • Jan 2024
      • 18
      Originally posted by Gaffers01
      Можете ли вы прикрепить фото побольше?
      in the photo it looks like entering the PC BIOS. and just see the current password. very small window in the middle.
      • Gaffers01
        • May 2011
        • 330
        Need to do "Special Altboot"
        • kropa
          • Jan 2024
          • 18
          Нужно сделать "Special Altboot"
          XeroxAltalink_C8170_ALTBOOT_system-sw#11401101128800#ENG_MOD.DLM
          I downloaded this album, I think this is what you are writing about?
          Only this one was accepted by the machine.
          • kropa
            • Jan 2024
            • 18
            the machine went through all the stages, rebooted several times and said remove the usb flash drive
            • kropa
              • Jan 2024
              • 18
              I created a folder as in the service manual, inside put the firmware file and two more files without extension
              DISABLE_DATA_BACKUP
              FORCED_UPGRADE
              • kropa
                • Jan 2024
                • 18
                There is a similar, exactly the same working machine. If I knew for sure that I could try to throw it from the working one so as not to break it, I would have thrown it.
                • xcopytech
                  • Aug 2006
                  • 1757
                  Check or replace hdd and then perform special altboot
                  Download files for special altboot
                  • kropa
                    • Jan 2024
                    • 18
                    I have a new HDD for this car. but the machine has stopped flashing and always asks for a password. I tried to put . maybe the main board will die?
                    • xcopytech
                      • Aug 2006
                      • 1757
                      Did you try special altboot
                      Do you know what is special altboot
                      • kropa
                        • Jan 2024
                        • 18
                        • kropa
                          • Jan 2024
                          • 18
                          Is this what flashes each component again, changing everything old?
                          • kropa
                            • Jan 2024
                            • 18
                            clear
                            ya sozdal papku
                            15 / 5 000
                            Результаты перевода
                            Перевод
                            I created a folder
                            clear
                            ya sozdal papku
                            15 / 5 000
                            Результаты перевода
                            Перевод
                            I created a folder alboot
                            placed it inside:
                            DISABLE_DATA_BACKUP
                            FORCED_UPGRADE
                            that's all what I know.
                            • kropa
                              • Jan 2024
                              • 18
                              Данная процедура восстановления появилась для altalinks 80xx и 81xx. Помимо dlm на флэшку добавляется директория с загрузчиком, что позволяет восстановить аппарат после замены диска или карты памяти. С большой долей вероятности на машине 80хх будет потерян весь биллинг.
                              это то, что мне нужно?
