Xerox WC 7665 09-548 Xerographic prob exists
  • copierpro
    • Apr 2007
    • 270
    When I power up I see a message Xerographic problem exists.
    So I power down copier, check the toners, check the drums, reseat, power up and message on control panel gone. Press make copy and machine just goes into limbo, showing graphic of paper going through copier on display, nothing happens.
    Delete job, go to web ui and login via IE. It states a fault code 09-548 exists. Look on Xerox site under fault codes and none exist like that. And that fault code does not appear on the control panel.
    Anyone got the fix on this irritant? Machine has only 20K total clicks and is like new.
    Thanks in advance
  • xcopytech
    • Aug 2006
    • 1794
    check fuser assy
    • copierpro
      • Apr 2007
      • 270
      fuser unit check
      looks completely normal great condition no paper gears food on fuser mod
      • xcopytech
        • Aug 2006
        • 1794
        does it warm up?
        • copierpro
          • Apr 2007
          • 270
          yes - the fuser gets plenty hot. The message on display will come up "Xerographic system problem" power down and off it will go away yest paper will not begin feeding from tray when you try to make a copy. And when I go to internet explorer and type in IP address I see "system fault code 09-548 copy or print functions not available"
          • xcopytech
            • Aug 2006
            • 1794
            can you enter in dignostic and see in fault history which fault is most recent
            • Milo Wilson
              • 503
              I looked in my EDOC and there isn't an error code listed for 09-548. That would seem to be a Xerographic issue but no code listed
              • copierpro
                • Apr 2007
                • 270
                latest fault code
                the latest error code is 20.331.00 next is 03.338.00 which don't say anyhing except color control comm failure power off wait three minutes power on which does zero to fix it.
                display reads "There is a problem with the Xerographic sysstem call for assistance"
                • copierpro
                  • Apr 2007
                  • 270
                  Centre Ware Internet Services
                  when I log in to 7665 form Internet here is what it says about ststem status:
                  09-548 - cannot print or copy
                  There is problem with the Xerographic system. User intervention is required to Power Off/Power On the machine. If the problem persists, Xerox Service is required. Copying and Printing are not available.
                  • xcopytech
                    • Aug 2006
                    • 1794
                    ๏ปฟ003-338 RAP
                    BSD-ON:3.2 PWB Communication (ESS - IIT) BSD
                    ESS PWB detected a communication failure between IIT and ESS. (IIT-ESS Communication
                    Fail 19.)
                    Procedure
                    If powering OFF then ON does not resolve the problem, perform the following:
                    1. Check ESS PWB and IIT/IPS PWB connections
                    2. Reinstall the software.
                    3. If the above actions do not resolve the problem, replace ESS PWB. (PL 11.5)
                    • copierpro
                      • Apr 2007
                      • 270
                      thanks - I have a Xerox tch here with laptop and he is udating software now - this machine has only 20K total on meter but it also say unused for over a year gefore I got it here. I think updating software is issue. Will let you know thanks.
                      • copierpro
                        • Apr 2007
                        • 270
                        I would not be causing this problem by using an aftermarket firewire ieee1394b from side rear of copier to controller box, would I?
                        The Xerox firewire that is silver cable is not proprietary is it? Can't be is my thinking - both are ieee1394b and both are 9 pin male each end.
                        the original firewire cable was missing when I got unit and I just ordered a replacement online. it is shooting no codes of its own on display
                        • xcopytech
                          • Aug 2006
                          • 1794
                          try to remove that cable ant power on machine.
                          if you get same problem then try with another cable.
                          • copierpro
                            • Apr 2007
                            • 270
                            actually the fireware cable works fine - if I remove the cable it never even goes to ready because it picks up a firewire communication problem before it even goes to ready
                            • copierpro
                              • Apr 2007
                              • 270
                              Well, nothing working. Still getting message on control panel "Xerographic system error call service"
                              Have checked drive motor for black drum it is OK; have updated system software to newest version; have put in new scorotron over drum, nothing working.
                              This has got to be something simple! Should I try a different drum? Though I here no drum drve chunks or gears grinding so it seems it should be OK there.
