DC12 not printing from Bypass tray
  • GusG
    • Jul 2008
    • 198
    Hi. My newly installed (but not new) DC12 (with Fiery X12 RIP) won't print to the bypass tray (tray 5) yet it did so yesterday. I get a message on the RIP saying "Selected paper size is not available" despite the tray setup on the printer and the printer driver matching.
    Any clues to solving this is highly appreciated, thanks in advance.
  • TzALbg
    • Dec 2007
    • 111
    Loosen connector PJ-416 on the main IOT PWB
    Reseat the connector
    • GusG
      • Jul 2008
      • 198
      Thanks, I'll try that
      • hachetman
        • Jul 2009
        • 96
        I remember a little about this try going to mother x's web page and download the lastest driver to match your os don't use the one that comes on the cd suppiled with the copier
        Steve Baker
        hachet1_12@outlook.com
        • GusG
          • Jul 2008
          • 198
          I haven't tried working on the connector but I realised that the bybass works just fine when I copy. I've tried all the drivers that I've found for Windows XP on X's site plus the one that was on the fiery itself. No joy.
          I've got the X12 v. 1.5 SP2 with the following patches installed:
          1-IT20F
          1-K32ZJ
          1-i7sg8
          Could it be needing a patch like the composite patch (over 400MB)?
          • davidj7
            • 1107
            are u able to change the settings to Tray 5 bypass in command workstation and does it work then?
            a machine is only as good as your tech : source:screwtape ; the scary one
            • xcopytech
              • Aug 2006
              • 1792
              do not instal composite patch
              composite patch is for version 1.5 not for 1.5 sp2
              ver 1.5 sp2 is newer and have composite patch in installation files.
              • GusG
                • Jul 2008
                • 198
                Yes, I've tried that and it still says "Selected paper size is not available"
                • GusG
                  • Jul 2008
                  • 198
                  Thanks, I'll stop the download right away
                  • davidj7
                    • 1107
                    are you able to select 12*18 on tray 5 in copy mode . you might have to activate the extended paper size option in the service mode
                    • GusG
                      • Jul 2008
                      • 198
                      Hi David, yes I can copy to 12x18". This morning I also tried to do an align trays on tray 5 from Workstation just to see if it would work, it didn't.
                      • davidj7
                        • 1107
                        let me get this right , you can copy from tray 5 in any size , any thickness. You cannot print from Tray 5 from a4 to 12x18 any thickness. is that correct?
                        • GusG
                          • Jul 2008
                          • 198
                          Yes, that's right, copying all sizes and thicknesses fine, printing any size or thickness not working
                          • xcopytech
                            • Aug 2006
                            • 1792
                            download composite patch from xerox site, install it and then download driver for fiery x12 ver 1.5 vith composite patch.
                            maybe your print driver is different then fiery system software version
                            • GusG
                              • Jul 2008
                              • 198
                              Yesterday Xcopytech told me that the fact that I have SP2 it already includes the composite patch. Also I have tried all the XP drivers I can find on the Xerox page including the Win 2000 one as well as one I got from the RIP itself, all give the same issue.
