How to clear Dcc320 code 9-910 ?
  • ymmtech
    • Jun 2009
    • 190
    Dear Sir, I got difficult of clearing the code 09-910.
    This machine originally have a bad NIC, but still can photocopy normally.
    After changing the ESS PWB and MCU PWB, it receiver 2 error code.
    103-208 and 09-910. I managed to solved 103-208 , but donn't know how to solve 09-108.
    09-910 say "Drum type mismatch k",
    Please help me. Thanks.
  • johnner66
    • Mar 2009
    • 265
    deu to the drum is different code go to the 751-168 change it to 48
    • ymmtech
      • Jun 2009
      • 190
      Thanks Johnner66.
      09-910 0->48 OK.
      I try to put 3 problem machine into 2 working one, now the other unit have 004-345 and 007-250. What should I do ?
      Is it OK to change the entire box (ESS PWB, MCU PWB HDD and Memory) at one go?
      Thanks.
      • copytech200X
        • 264
        Originally posted by ymmtech
        Thanks Johnner66.
        09-910 0->48 OK.
        Thanks.
        if u chg this 3 items one go will effects meter reading and serial number..
        • copytech200X
          • 264
          004-345 IOT HVPS communication fail due to the hvps connector ...
          007-250 TRAY COMMUNICATION FAIL chk connector between tray module pwb and mcu pwb.
          i suggests u recheck all connector ....good luck
          • johnner66
            • Mar 2009
            • 265
            for the ser. no. u need the psw to read write it
            • copytech200X
              • 264
              ess pwb 8 pin IC contains meter reading and serial number ,remove it to new ess pwb ,.......
              • ymmtech
                • Jun 2009
                • 190
                Thanks both of you.
                004-345 is HVPS control PWB spoilt.
                Not sure if the tray module spoilt, 007-250 warning gone if cable to this unit is not plug in.
                Now the NVM is being initialized, need calibration.
                I have PSW 2GEN Ver2.0.0E EDOC and old universal programer. But have no experience on tuning this machine, do you have some reading material on how to fine tune the colour printing? or any similar knowledge base ? Or at least show me first few step to do.
                Thank you very much for your advice.
                • copytech200X
                  • 264
                  Thanks both of you.
                  copy quality calibration u need do max setup and confirm all developer ATC sensor number eg:043 refer edoc ADJ 9.1.2 (ATC sensor setup)and followed by ADJ 9.1.4 (ADC output check)and IIT calibration...and do regi adjustment DC685 regicon setup cycle follow step by step...good luck
                  • ymmtech
                    • Jun 2009
                    • 190
                    Thanks copytech200x.
                    will try it out next week.
