Xerox DC2060 error 010-312
  • raptor
    • Aug 2025
    I replace Belt Fuser Assy in DC2060.
    The printer shouts that error 010-312 (Press Subsystem Fault: 010-312).
    Will someone help maybe?
    Sorry, my english is not perfectly.
    Greetings.
  • jayc67
    Independent technician
    • Sep 2009
    • 100
    Hello,
    Check the fuser belt latch motor. If you don't have PWS go in diag on DC330 and check the 10-002, the motor start?
    If not, check for damage or check the fuser belt latch sensor.
    Tell me what happens? and if you don't find the part, i can send you picture.
    • copytech200X
      • 264
      010-312 fuser heat roll sts-2 disconnection fail
      1)Check if the drawer is pushed in with the fuser unit improperly seated before the power is turned on.
      2)check the connector (p/j 147 black)heat roll thermistor 2 are connected.
      3)chk drawer connection (p/j 612)connecting to fuser unit and the main unit are free from bent pins,foreign objects and burnout.
      if above are good then remove fuser unit .disconnect the connectors (p/j 147 black on the heat roll thermistor 2 and measure resistance between pins 1 and 2
      resistance is infinite?yes ,replace heat roll thermistor2
      no,replace MCU pwb
      good luck
      • raptor
        Thank you jayc67. Victory!
        I found latch sensor.
        This part caused error. Sensor fell out from the handle (chuck, shank?), ehh.. i apologize too my bad English.
        They once again thank.
        copytech200X - i also thank for hints.
        Greetings.
        • copytech200X
          • 264
          glad to hear that you did it...
