DC-12 "insert coin" message
  • Milo Wilson
    • 503
    #16
    Is there any device plugged into the machine anywhere? Like an extra plug/cable on the outside of the machine?
    • inSrouce
      #17
      dc12bottom..jpgdc12top..jpgthese are the only plugins besides power.
      • Milo Wilson
        • 503
        #18
        That cable plugged in below the two wide interface cables at the top back...what does that go to? That is not a typical cable connection used on the Doc 12/50. Get a pic of what that cable is plugged into and post.
        • Milo Wilson
          • 503
          #19
          Does your DC50 have an edit pad? Or an RDH on top?
          • inSrouce
            #20
            dc12cables..jpgdc12backcables..jpgdc12front..jpgthe smaller grey cable is attatched to the "stapler" on the upper left of the full view picture.
            • inSrouce
              #21
              I apoligize. the small gray cable under the two other cables plugs into the top "scanner cover" unit.
              • JimmyB
                • Jun 2008
                • 77
                #22
                on the top is EDIT PAD, not scanner.
                to disable "insert coin" change NVM
                700-096 PA Entry Key - Coin Kit
                To enable or disable PA Entry Key Display (for Coin Kit)
                0= OFF
                1= ON
                • inSrouce
                  #23
                  0= OFF
                  1= ON
                  nvm 700-096 value = 0
                  stil says insert coin.
                  steps Im taking:
                  Turn machine power on.
                  xerox screen
                  4 beeps
                  "insert coin"
                  hold 0 and "start" big green button.
                  enter 6789
                  nvm edit
                  enter number
                  700096 value = 0 new value = 0
                  close
                  machine reboots into options screen
                  done
                  machine reboots
                  xerox screen
                  4 beeps
                  insert coins
                  "MUTHER F####"
                  thats pretty much been my morning
                  WHAT AM I DOING WRONG?
                  I hope its just an ID-10-T error on my behalf!
                  Thanks for the help!
