DC-12 "insert coin" message
  • inSrouce
    • Jun 2025
    [Error Code] DC-12 "insert coin" message
    Hello, I recently purchased a DC-12 machine, and it says to insert coin, I would love to, but alas, the coin operation unit did not come with the machine, Can someone please help me clear this message so I can use my "new to me" machine?
    Neal
    509-251-3396 or email nealiodee@hotmail.com
    or just post here
    THANK YOU!
  • kandod
    • Mar 2010
    • 58
    Neal
    or just post here
    THANK YOU!
    amazing
    • bojans
      • 1313
      Is there any error code?
      • inSrouce
        "amazing"
        sorry, that didn't work either. I'm not sure if you are trying to point out that I don't know what I am doing or that you don't know the answer, but in the time it took you to post "amazing" as an answer, you could have just as easily stuck your head up your @$$ and saved us all the snide remark.
        "Amazing" just wont cut it. I have spent several hours trying to even reset it to a "default" setting, but that doesn't seem to work either. I would appreciate an appropriate answer from a qualified technician.
        Thanks.
        • inSrouce
          No error code to speak of, it just says "insert coins" and I can access all the tools, counter etc.. options.. just wont do anything else past "insert coins"
          • bojans
            • 1313
            Can you check NVM value 759-015, and post back result?
            • Milo Wilson
              • 501
              Need to disable coin op nvm settings. I can't recall which one it is but the searchlight will point you in the right direction on the PWS. It really isn't a major issue, just find it and set it correctly.
              • inSrouce
                nvm value 759015
                value = 0
                • inSrouce
                  Milo, thank you for the response, unfortunatly, I do not have access to any PWS software or anything of this nature. I would gladly paypal you some "coin" (pun intended) if you can help me out.
                  Neal
                  • Milo Wilson
                    • 501
                    Check nvm 752-002 make sure set to 0 to disable foreign interface device. I think that should do it.
                    • JustManuals
                      • Jan 2006
                      • 9838
                      This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from:
                      Copiers-Printers-Fax - products new home - . <<-- Direct link. The information is there. 75mb 1617 pages.
                      Paul@justmanuals.com
                      • kandod
                        • Mar 2010
                        • 58
                        Thanks.
                        Sorry inSource, I never heard of such an "insert coin" option, I really thought is was some kind of cheerful joke.
                        • inSrouce
                          now what?
                          okay, so I go thru the motions, change value to 0 and then when I hit close, it "reboots" goes back into the options screen I hit done and it reboots again, but the value goes back to 1. ?
                          it doesnt seem to save the 0? blah.
                          • bojans
                            • 1313
                            stupid question but did you press Start button to save that value?
                            • inSrouce
                              yes of course. I also went back in before I exited and "checked" the nvm value, as if I was going to chenge it again and it stayed 0. until I hit close. once I hit close, it "reboots" back into the options even check the value and its back to 1. blah.
                              how bout just a master reset to replace all nvm values back to a default "out of the box" situation??
