Fuser fan C32 style
  • bojans
    • 1313
    Fuser fan C32 style
    Has anyone ever figured out what was going wrong with Fuser Fan PN 127K29340 for Xerox models CopyCentre C32, C40, (DocuColor) DC1632, DC2240, DC3535, (WorkCentre) M24, M32, ...
    It's very common failurewith these machines. I smashed one yesterday and found that one resistor had loose contact. Something like resistor on CCD Board on C35, M35 b/w machines. I wonder if this could be the problem. I will try to solder that resistor and post back with the result.
    This Fan is not expensive but sometimes needs 30 days for delivery , so i need a way to make it work for a while..
    Pozzz
  • pepperbrick
    • Mar 2009
    • 17
    hi, this error happens due to slow down of motor speed.
    You may want to try clean the brush contacts to see if it helps.
    good luck - do post ur test result !!
    • bojans
      • 1313
      I tried to clean it but that's not the problem. As I first post, it's electronic problem... now i'm testing my solution. After i confirm, I'll post back.
      By
