C2128
  • adeyemi
    • 378
    C2128
    I traced the fault on this machine to the CCM NVM pwb and ordered a new one. But after replacing and doing the Instl Config stuff for proper configuration, it tries to come up ready but immediately after coming up ready, it goes down again with a power up fail message. When i checked last 40 faults, i saw a 22-352. Can anyone give an idea on this, thanks
    Dgtal
  • tower
    • Feb 2010
    • 28
    I have the same problem, the solution and the following
    dC132 Serial Number Synchronize
    Purpose
    Generates unique machine identifier and with password synchronizes Machine Serial Number
    when fault 22-352 occurs.
    Procedure
    1. Notify service support.
    a. Call service support for instructions.
    b. Complete reserialization form provided by service support.
    2. Reserialize machine.
    a. Enter the Diagnostic Mode. Refer to Entering Diagnostic Navigator.
    b. Select Adjustments tab
    c. Select Install/Cfg (DC371) tab
    d. Synchronize Serial Number.
    i. Select S/N Synch (DC132).
    ii. Select Generate Id.
    iii. Call service support and report Unique Machine Identifier.
    iv. Enter Password from service support into Submit Password.
    v. Select Submit Password.
    Serial numbers are now synchronized.
    I could not solve my problem, if you find the solution to me I know you do to me because if I find something I'll know.
    • adeyemi
      • 378
      i generated my machine unique id, but i don't have access to xerox service support, is there no crack that can generate the needed password anywhere? can someone help out there on this???
      Dgtal
      • Ajaxfan77
        • Sep 2009
        • 47
        Hi
        I'm also looking for password to synchronize those serial numbers... Problem is that those machines have to be on contract, but maybe someone has old ID and password
        Gr
        • tower
          • Feb 2010
          • 28
          I have the same problem on WorkCentre Pro C3545
          • adeyemi
            • 378
            something tells me there's someone out there that can help out on this matter.....plzzzzz do this for us!!!
            Dgtal
            • tower
              • Feb 2010
              • 28
              Try to read this
              http://www.copytechnet.com/forums/xe...te-serial.html
              • adeyemi
                • 378
                Thanks Tower, after reading the link above, I swapped the battery of my old CCM NVM chip with that of the new one and fixed the new chip (with the old battery) on the machine and guess what?? The serialization fault code, 22-352, disappeared from the last 40 faults table, although its still saying "power up fail" when it tries to initialize. The only fault on last 40 now is 03-338, CCM reset. So anyone knows where do i go from here? I'll continue trying stuffs and update you guys anyway!
                Dgtal
                • Goshe
                  • Jul 2009
                  • 118
                  This is what EDOC says about 03-338, CCM reset. The watch dog timer timed out or the application software wrote to an illegal address. Reset the Main Controller or Switch the power off then on. Perform dC361 to restore NVM from MRD. If the problem continues, perform dC102 SW Upgrade.
                  • adeyemi
                    • 378
                    Can someone pls explain why at times its so difficult to connect with this machine on the pws. The pws identifies and instals the usb port connected to the machine; diagnav verifies the usb connection but thereafter it just keeps saying "waiting for machine" until the assigned 90secs expires.
                    Dgtal
                    • simpel
                      • Jun 2010
                      • 25
                      "I traced the fault on this machine to the CCM NVM pwb and ordered a new one." where do you order this?
                      • adeyemi
                        • 378
                        jdean@dandrproducts.com
                        Dgtal
                        • artphil
                          • Aug 2008
                          • 155
                          Hi Adeyemi,
                          It's often an driver issue within windows.
                          Please uninstall the driver and reinstall it.
                          Worked for me.
                          Kind regards,
                          Artphil
                          • adeyemi
                            • 378
                            Thanks Artphill
                            Dgtal
                            • mpact
                              • Jan 2008
                              • 28
                              Re: C2128
                              Where did your order this part from?
