Problem quality print Xerox C2424 with solid ink
  • feroci
    [CQ] Problem quality print Xerox C2424 with solid ink
    Dears.....
    I have a problem with my printer.
    The printer is used. Model Xerox C2424 with solid ink.
    The press is always with vertical lines
    I have done many laps cleaning strips
    I also clean the roller with a cloth.
    How can I fix this problem?
    The maintenance kit is 57% remaing. About Total print 23k.
    Thanks a lot
  • hughesxrx
    • Jun 2010
    • 10
    print head
    • phasermajstr
      • Dec 2008
      • 9
      Originally posted by hughesxrx
      print head
      Even if it has a small number of prints it doesn't matter. The printhead is 100% broken.
      • feroci
        Thanks dear friends. Bad news
        You think it will change?
        How much the print head?
        Where I buy the head?
        The replace is easy ?
        The head is repaired?
        Thank a lot
        • phasermajstr
          • Dec 2008
          • 9
          Sorry you can't repair the printhead. And it also cost's more than 1000€ so it's better to buy new printer. Unless you find one with some other problems and with good head but I think that's also impossible. Otherwise changing the printhead is easy.
          • feroci
            thanks phasermajstr
            how sad ... I threw money of work harder
            Who knows what the part number?
            • phasermajstr
              • Dec 2008
              • 9
              650435400 Printhead assy
              • feroci
                I do not know what to do
                You see the response of iteminc.com Company
                quote:
                "pagina di pulizia" is showing light stripes. So, the printhead may be bad 650-4354-00 $595 refurb / $850 new. You may be able to use "jet subsitution" to regain some of the jets, but it seems like it could be too many.
                The dark smear may also mean a bad wiper 367-0534-80 $59.
                • Dexor
                  • 223
                  I had a similar problem; remove the unit and clean the surface (where the tiny holes are) of the printhead. It was a lost cause situation so I took the risk, and it worked. Prints are not perfect but quite acceptable to the customer.
                  • feroci
                    Thank you Dexor. I hope to solve the problem.
                    how remove the unit and clean the surface ?
                    there is a document step by step?
                    thanks
                    • Dexor
                      • 223
                      there is a step by step?
                      REmove the df, side panels (very few screws, as I remember only two in the back?) and it does feel like you're going to break them; those things are so honory!
                      Follow the manual, even though it's not always to the point. As I remember, you must remove the grounding spring/plate on the side. There are two boards attached, not difficult to remove/reinstall.
                      • feroci
                        thanks, unfortunately I am not the manual
                        • mwillems
                          Further Query
                          This is good stuff but I want to just get a bit more detail if that is ok.
                          I have the print head off my C2424 to clean it. I have taken the blade off the head to expose bronze coloured transparent ribbon with the fine holes in it.
                          How do I clean this? What cloth and or solution do I use to clean the head?
                          And how do these small holes provide ink across the entire paper?
                          I have purple ink inbetween the green circuit board and the bronze ribbon
                          Mark
                          • MikeSoW_Utah
                            c2424 light stipe
                            Dears.....
                            Thanks a lot
                            This link will resolve MOST light stripe issues - it will consume quite a bit of ink and though it implies 8400's it is also for the c2424 WorkCentre C2424 File Download #48510=
                            • MikeSoW_Utah
                              Try this link - it solves this issue 99.9% of the time if you are using good ink WorkCentre C2424 File Download #48510=
                              YES it is for the c2424
