Very Slow Printing Workcenter 4150
  • ares
    • Jul 2025
    I have a Xerox Workcenter 4150 that I am working on that is printing extremely slow. Even the test page has a delay of 20-30 seconds. The problem is both with PCL and with postscript drivers. Also from windows and mac's. I also tried printing to it from my windows PC via crossover. Any ideas will be greatly appreciated. Thanks.
  • tech9
    • 216
    changed the protocol on the driver from raw to lpr then type lp in the queue name.
    • ares
      I tried lpr but did not change the Queue name. I will try that...have you had this problem before?
      • tech9
        • 216
        yes, and sometime last year or earlier this year, i remember trying this and a memory clear plus HDD reformat on 4150 manage to get it going but can't remember which one cured it . But i have also had it WCP255 family and the first tip worked.
        Good luck
        • ares
          I will also i give that a shot if the LPR change doesn't work...thanks for the help... I really appreciate it.
          • kenrobol
            How do I do that?
            How do I change the driver name?
            • needlesgxe
              • Aug 2008
              • 30
              try
              turn off the machine
              unplug machine from power
              pull the back cover off
              unplug the battery (buttom right cover) leave unpluged for a min or two
              plug battery and power plug
              u can also do a "clear all memory" this erase any setting for scanning.
              also pulling out the hdd a formating it. make shour its Fat32 Format.
