Xerox Document Centre C320 error 006-380
+ More Options
Posts
  • Clif
    • Jan 2007
    • 49
    [Error Code] Xerox Document Centre C320 error 006-380
    Hello
    I have a C320 in the field displaying error 006-380 after the copier was reassembled after a service. I removed the PCUs, transfer unit, laser lense, developer units & toner units, cleaned & reassembled.
    What does this code indicate & how would I resolve the issue? I do not have a manual for this model.
    Any help appreciated.
    Clif
  • copytech200X
    • 264
    6-380 ROS SOS Y Length
    The interval of the ROS SOS (Y) signals exceeds the specified value.
    Procedure
    +5VDC is measured between the MCU PWB P/J401-B20 (+) and ground (-)
    Y N
    Replace the MCU PWB (PL 13.1).
    Check the wire between the SOS PWB (Y) P/J516-1 and the MCU PWB P/J401 for an open
    circuit.
    Check the wire between the LD Drive (Y) J529 and the MCU PWB P/J401 for an open circuit.
    If no problems are found, replace the ROS Assembly (PL 3.1).
    If the problem continues, replace the MCU PWB (PL 13.1).
    • Clif
      • Jan 2007
      • 49
      Thanks CopyTech200X
      I did remove the laser unit so I'll check the connectors.
      Regards,
      Clif
      • chaney101
        Re: Xerox Document Centre C320 error 006-380
        Did the laser end up being the problem here? I am having the same problem with this code on a 1632 Docucolor. It worked great, we moved it and now code? Frustrating.
        • Clif
          • Jan 2007
          • 49
          Yes. the laser was the problem. I left a cable unplugged.
          • chaney101
            I took the board out and found a burn on the incoming side of the power flow.
