xerox 510DP error E4-01 false fuser jams
  • W242
    • Aug 2009
    • 43
    [Error Code] xerox 510DP error E4-01 false fuser jams
    I have a Xerox 510dp wide format copier and I'm constently getting error E4-01 false fuser jams. I've cleaned the contacts for the fuser drawer, no change. Does anybody out there know what is causing this and how do I fix it?
  • xcopytech
    • Aug 2006
    • 1794
    did you test sensor from diagnostic?
    • W242
      • Aug 2009
      • 43
      Sensor checks ok. the macine will run 1 to 50 sheets before error. never any damaged, jammed or stuck paper.
      • xcopytech
        • Aug 2006
        • 1794
        maybe sensor actuator hang.
