Hello all,
I'm relatively new to the copier repair world as I've only been working on them for a little over two months. Anywho, I've been working on a Xerox Workcentre 5030 that has me whooped. Copying from the glass, everything works fine. The trouble is when I copy through the ADF. It will make the copy and then say there is an unexpected timeout which can be cleared by simply opening and closing the front door. I checked the paper sizes of the trays and everything is programmed correctly. Feeding paper through the bypass tray doesn't work either. If anyone can be of any help I would greatly appreciate it!!
