Xerox 238
  • linuxxpwin
    • May 2008
    • 205
    Wow interesting, I will try it however and let u know if it did work, but I prefer to have software and manuals thanks in advance bojans.
    Linuxxpwin
    • bojans
      • 1313
      Linuxxpwin
      Sometime tomorrow I'll upload files and send you link.
      BR
      • bojans
        • 1313
        Check this!
        DocumentSpeedMismatch.pdf
        • linuxxpwin
          • May 2008
          • 205
          #19
          Originally posted by bojans
          Does this pass work with all machines? Aren't you supposed to give machine serial number, and get back pass code?
          I have been doing some reading and if I can get into 03-008, my setting should be 78 which is WC38BMF.
          • linuxxpwin
            • May 2008
            • 205
            #20
            Check this!
            [ATTACH]8338[/ATTACH]
            Very interesting reading, I am very pleased with the info provided, I have been doing quite a lot of reading and I will post update tomorrow.
            Thanks in advance.
            • linuxxpwin
              • May 2008
              • 205
              #21
              Check this!
              Ok gentle men
              The passcode did work and I was able to change settings however problem persist, I then use the attachment reading provided by bojans and the final part did work by setting 08-001 of the IOT to 7 allowing the machine to configure it self.
              I would still like to have relevant documentation on this machine (manuals, software, etc) and I am willing to make a donation to get them.
              I am the only tech here covering a lot of these machine so I need all relavant resource available.
              Thanks in advance
              Linuxxpwin
              • bojans
                • 1313
                #22
                Ok gentle men
                Thanks in advance
                Linuxxpwin
                Glad to hear that everything is working now.
                Send me your e-mail address, so I can share dropbox folder with you.
                • linuxxpwin
                  • May 2008
                  • 205
                  #23
                  Ok I send you my email address check pm inbox.
                  Thanks again in advance.
                  • Guest
                    #24
                    No!
                    Only 2xx and 56xx series!
                    • a.ghafari
                      • Sep 2009
                      • 46
                      #25
                      If you need the password to change some NVM link in DC 131 like machine speed use this:
                      (2845490).tel me if you use this and the problem is steel.
