Odd persistent banding issue with my DC 3535
  • GusG
    • Jul 2008
    • 198
    Hi,
    I've got an issue with lines 90 degrees to the print direction (i.e. parallel with the drums), you can see them on the attachment (there's a magenta tinge in the yellow on the attachment, that was just a bad drum and not part of this issue). I guess it's what the service manual calls high frequency banding, it started becoming evident in black but now seems to be in all colours though still most evident in black.
    We've tried the following:
    - Checked the seating of RAM and NVM PWBs as well as for loose connections at ESS PWB (as the service manual recommends), this only resulted in the harddisk needing changing and the software put on, in fact changed several of these things from a spare 3535 I have with no luck
    - Changed the black developer unit 4 times when this was most noticeable in black, no change
    - Changed the ROS, same story. I have one other ROS I can try with but haven't yet
    Any ideas out there?
    Cheers,
    Gustav
  • Scarecrow
    • Oct 2010
    • 234
    Transfer belt? Cleaner?
    • adriansto
      • 2387
      I think is a HVPS problem. Remove drums, belt assy and developer units and make a good clean. Be sure you clean the contacts very good. Try again to make test. If the defect is still there then change HVPS.
      • GusG
        • Jul 2008
        • 198
        Thanks for the suggestion. I can't say for sure if my tech did clean all these bits when he's had the machine open to change the dev tank but he's usually quite good at that sort of thing, can't get him til Monday though. I did change the HVPS just now (from a spare 3535 that didn't have this issue when it was running) and that has not eliminated the problem though it appears to be ever so slightly better.
        Any other suggestions welcome
        • adriansto
          • 2387
          May be 2nd BTR assy.
          Make 15 copies of A3 or (8.5x11) paper with 4 color 70% selected.
          When near end of the run crash stop machine with the paper in fuser.Carefully remove the jammed sheet and examine IBT belt, the non transferred image on the belt should look ok, but the residual image left on the belt after transfer will have the bands visible, (the old 2nd BTR assembly will look perfectly ok).
          • GusG
            • Jul 2008
            • 198
            I'll have a look at that tomorrow. I've actually been suspecting the 2nd BTR as the problem is more pronounced the heavier the paper, virtually no problem on bond, so that would already indicate that the problem is not on the IBT
            • adriansto
              • 2387
              test.jpgBanding at 1.5 mm interval. Bad developer housing. most noticeable on heavyweight paper
              • RockETop
                Curmudgeon at large
                • Apr 2007
                • 171
                Try your developer drive units. I don't know this machine, but have seen it on others.
                • CT Copier Repair
                  • Mar 2010
                  • 304
                  Developer housings
                  seen it many times on DC's
                  then go for the 2nd BTR contacts and clean unit
                  • GusG
                    • Jul 2008
                    • 198
                    Thanks for all your suggestions. I've tried changing the 2nd BTR with no luck, then I did the crash stop of a print as suggested by adriansto and the banding is evident on the IBT belt (I know I did this the wrong way around but I had to change the 2nd BTR anyway). The machine was thoroughly cleaned not so long ago but we may try to do that again.
                    About the developer units, I can't rule that out completely but we have changed the black one 4 times, although they were all used ones it seems unlikely that they should all be at the same level of "badness".
                    Any further suggestions?
                    • GusG
                      • Jul 2008
                      • 198
                      Now it gets weirder, we discovered that if we print some 10 sheets of each of CMYK solids then the lines disappear for some time.
                      We first noticed when we were printing several thousand A5s with very little toner coverage that after a while the prints started getting mottled, so we did the solid CMYK thing to try to force some toner through, the mottling disappeared as well as the lines.
                      There obviously still is a problem even if we've found a workaround, could it be tired developer material?
                      • adriansto
                        • 2387
                        Do a good cleaning of the machine in particular the electrical contacts to de developer an IBT assy
                        Then run the MAXSETUP from service.
                        • azehnali
                          • Nov 2009
                          • 679
                          do you have the same issue from the glass?
                          • GusG
                            • Jul 2008
                            • 198
                            Yes, it's the same
                            • RockETop
                              Curmudgeon at large
                              • Apr 2007
                              • 171
                              See above.... Try the developer DRIVE unit(s).
