010-320 fuser and dead touchscreen
  • digital novice
    • Jul 2025
    [Error Code] 010-320 fuser and dead touchscreen
    I had a fault code 010-320, my fuser died when I tried to start my machine in extreme cold. I didn't realize the cause until I was researching it a couple of days ago. I tried to clear the fault code using the touchscreen, but wasn't able to because I had not yet replaced the fuser. This morning, I replaced the fuser, but the fault code still appears. When I tried to clear the fault code, I discovered the touchscreen is no longer working. Are the two related, and how can I fix this? There is no alternative, that I know of, to using the touchscreen.
    The fuser fault code 010-320 occurred once before, a year ago, but all I had to do was replace the fuser. So I'm not sure if these are related, or if I have a gremlin in my machine.
  • adriansto
    • 2387
    Originally posted by digital novice
    ....The fuser fault code 010-320 occurred once before, a year ago, but all I had to do was replace the fuser. So I'm not sure if these are related, or if I have a gremlin in my machine.
    And the machine name is ?
    • digital novice
      sorry... xerox docucolor 250
      an oldie, but goodie (when it works)
      • JustManuals
        • Jan 2006
        • 9838
        Just Manuals | The Internet's largest selection of manuals | Instant Downloads
        Paul@justmanuals.com
        • elsab
          • Dec 2007
          • 63
          There might be problem on AC Power Unit but try to reset first the NVM (744-350=0)? not sure for this model, for fuser overheat (10-320)
          • azehnali
            • Nov 2009
            • 679
            you first need to replace the UI ( touch screen)
            • digital novice
              Is it possible to reset without use of the UI/touchscreen?
              • Milo Wilson
                • 502
                You need a PWS laptop to be able to reset without the UI screen.
                • elsab
                  • Dec 2007
                  • 63
                  try to reseat dimms in ess pwb for possible cause of touchscreen hang up. then reset nvm for 10-390 while front door open.
                  • maich4s
                    • Mar 2009
                    • 86
                    the dead screen also happened to me once on the same dc250 model,what i did i just opend up the touch screen disconected and reconected the connectors and it was up and running again.try it it will save you lots
                    • amadeusmbi
                      • 51
                      Reseat UI cable.
                      Try first a calibration of the UI (PO-0, 1,3) then, if it works, try reset 010-320.
                      "Opportunity is missed by most people because it is dressed in overalls and looks like work. "
