Can someone tell me how to reset this error ( the fusser unit is cheked and OK ) or give me link for service manual. I can change that manual for one or two for Ricoh.
PLS help
Press menu, *, # SOS1 will appear on screen, press OK on Sos1& change the first 0 that is blinking to 1.
Then press stop twice & open the front, then enter menu, #, T
This will reset the fault
There are 2 configurations of the printer requiring 2 different Main Boards. The 4 in 1 main
PWB for the 3100MFP/x (with ADF), and the 3 in 1 Main PWB for the 3100MFP/s (no
ADF). The procedures below are used to reset a fuser error.
4 in 1 Main PWB (3100MFP/x):
Step 1: Select "Menu" or the down arrow
Step 2: Select "*"
Step 3: Select "#"
Step 4: Select "OK"
Step 5: At the SOS change "00100001" to "10100001"
Step 6: Select "OK"
Step 7: Select "Stop"
Step 8: Select "Menu" or the down arrow
Step 9: Select "#"
Step 10: On the keyboard select "T"
Step 11: Power off/ Power on (PO/PO)
Try making 1 copy (for checking)
Step 12: Select "Menu" or the down arrow
Step 13: Select "*"
Step 14: Select "#"
Step 15: Select "OK"
Step 16: At the SOS change "10100001" to "00100001"
Step 17: Select "OK"
Step 18: Press "Stop"
3 in 1 Main PWB (3100MFP/s)
Step 2: Select "*"
Step 3: Select "#"
Step 4: Select "OK"
Step 6: Select "OK"
Step 9: Select "#"
Step 10: Scroll up to "T" Printer
Step 11: Select "OK"
Step 12: Power off/ Power on (PO/PO)
Step 13: Select "*"
Step 14: Select "#"
can someone tell me hot to press T key or scroll to T key since I have a model 3100MFP without fax and with no keys on the right.
Also what exactly is fuser temp error and how can this procedure fix it, since I was told that probably I have a fault fuser (termistor) and that whole unit should be replace.
