PHASER 3100 MFP printer error fuser temp resetting
  • zoran.riko
    • 54
    Can someone tell me how to reset this error ( the fusser unit is cheked and OK ) or give me link for service manual. I can change that manual for one or two for Ricoh.
    PLS help
  • JustManuals
    • Jan 2006
    • 9838
    What do you have to trade? Email me.
    Paul@justmanuals.com
    • jeanpaul
      • Mar 2009
      • 117
      Press menu, *, # SOS1 will appear on screen, press OK on Sos1& change the first 0 that is blinking to 1.
      Then press stop twice & open the front, then enter menu, #, T
      This will reset the fault
      • ingmaster
        • Mar 2011
        • 39
        There are 2 configurations of the printer requiring 2 different Main Boards. The 4 in 1 main
        PWB for the 3100MFP/x (with ADF), and the 3 in 1 Main PWB for the 3100MFP/s (no
        ADF). The procedures below are used to reset a fuser error.
        4 in 1 Main PWB (3100MFP/x):
        Step 1: Select "Menu" or the down arrow
        Step 2: Select "*"
        Step 3: Select "#"
        Step 4: Select "OK"
        Step 5: At the SOS change "00100001" to "10100001"
        Step 6: Select "OK"
        Step 7: Select "Stop"
        Step 8: Select "Menu" or the down arrow
        Step 9: Select "#"
        Step 10: On the keyboard select "T"
        Step 11: Power off/ Power on (PO/PO)
        Try making 1 copy (for checking)
        Step 12: Select "Menu" or the down arrow
        Step 13: Select "*"
        Step 14: Select "#"
        Step 15: Select "OK"
        Step 16: At the SOS change "10100001" to "00100001"
        Step 17: Select "OK"
        Step 18: Press "Stop"
        3 in 1 Main PWB (3100MFP/s)
        Step 2: Select "*"
        Step 3: Select "#"
        Step 4: Select "OK"
        Step 6: Select "OK"
        Step 9: Select "#"
        Step 10: Scroll up to "T" Printer
        Step 11: Select "OK"
        Step 12: Power off/ Power on (PO/PO)
        Step 13: Select "*"
        Step 14: Select "#"
        • svizoman
          Re: PHASER 3100 MFP printer error fuser temp resetting
          can someone tell me hot to press T key or scroll to T key since I have a model 3100MFP without fax and with no keys on the right.
          Also what exactly is fuser temp error and how can this procedure fix it, since I was told that probably I have a fault fuser (termistor) and that whole unit should be replace.
