DC6060 fuser compatibility with a DC2060
  • GusG
    • Jul 2008
    • 198
    I've someone offering me a DC6060 fuser and I'm wondering if that is any good for my DC2060. I know it's not identical as I once got a fuser web for a 6060 that did not fit my 2060 but are some other bits compatible?
    For instance:
    - Would I be able to just slot the 6060 fuser into the 2060?
    - Would the 6060 fuser belt assembly be compatible with my 2060 fuser?
    Thanks in advance.
    Gus
  • TechMate
    • Mar 2008
    • 285
    Re: DC6060 fuser compatibility with a DC2060
    For instance:
    Thanks in advance.
    Gus
    Not a good idea
    • SEnder
      • Jun 2008
      • 36
      Its not the same. As far i know, same is heat roll, fuser belt, oiling. 6060 have two external rolls, web assy is diferent.
      • GusG
        • Jul 2008
        • 198
        Thanks, so do you think the fuser belt assembly is the same?
        • davidj7
          • 1107
          you can salvage for parts , I dont think you can use it as a drop in replacement .
          a machine is only as good as your tech : source:screwtape ; the scary one
          • Milo Wilson
            • 508
            Fuser belt assy is the same. Take from the 2060 and drop in 6060
            • xerotec
              • Oct 2009
              • 45
              fuser belt assy from DC6060 can use in DC2060 bat from DC6060 can't use in DC6060 becouse DC6060 have some roller uder fuser belt assy
              • Milo Wilson
                • 508
                That roller assy isn't really used for anything. You can use the 2060 fuser belt assy in a 6060
                • GusG
                  • Jul 2008
                  • 198
                  Thanks guys, that's what I wanted to hear. What I want to do is take the assy from a 6060 and stuff that in a 2060 so I guess I'm safe, roller or not.
