Does anybody have a service manaul for the Doc 12 and can look up the code 9-363. I am an ex-technician but with out a service manual. Any help is greatly appreciated.
Xerox Doc 12 error code 9-363
Sdcoloretch
9-363 is the developer housing rotary system did not reach home position. Unfortunately this is not usually a simple fault.
Have you made a lot of Black and White copies?
If so you may have to replace the developer and perform a MAX setup.
I really would recommend that you get a service engineer to look at it unless you are absolutely certain that you know what you are doing. -
Sdcoloretch
Xerox Doc 12 9-363
Hi,
Thanks for the response. I already fixed the error. It was one of the fuses in the rotary PWB.Comment
Sdcoloretch
9-363
Thanks, I noticed that the error came back once when I made a black and white copy. I have changed the NVM's and will monitor. I appreciate the help.
RonComment
carlos
Hello please, I have the same problem, where this sensor is located exactly? and fuses? I like to watch them to fix my machine, I was very urgent. thank you very muchComment
mustangnz1
