Xerox DC 2060 Error code 010-357
  • Ignis
    • Aug 2010
    • 28
    [Error Code] Xerox DC 2060 Error code 010-357
    Hi, every time when I'm turning on the machine, after warming up..(4-5 min.) this error appears.. It says turn off the machine and waith 5 sec. then turn it on again! and when i do that..its fine, but why it appears every time?!
    It started appearing after I changed the upper roller on fuser. I know that error code was abot fuser..it says: 10-357 Fuser Heat Roll Warm Up Fail RAP
    I checked fuser visually if any cable is disconnected, but i don't see anything.
    Maybe someone can help me with this?
    Can i just rest something in PWS?
  • azehnali
    • Nov 2009
    • 679
    Re: Xerox DC 2060 Error code 010-357
    why dont you follow the raps for the error code
    • Ignis
      • Aug 2010
      • 28
      I dont have RAP descriptions for error codes! Where can i get it?
      I only know that i need this RAP code 2-294
      • azehnali
        • Nov 2009
        • 679
        10-357 means that the fuser heat roller did not warm up in time
        either the lamp is bad or no power to it
        does the lamp come on
        when you push the tray in and close the handle does the pressure belt engage
        • Ignis
          • Aug 2010
          • 28
          yes, the lamps came on, i see them. And when i close the handle i can hear how pressure belt engage every time.
          I noticed that this happens mostly when first starting the machine in the morning .. later during the day when I put him to sleep, it will be on 2-3 hours sleep .. Then when I wake it up and when it warms up again everything is ok and no longer throws an error. ....strange
          • azehnali
            • Nov 2009
            • 679
            Probably your thermistors are worn outCheck them next time you change the heat roller
            • GusG
              • 198
              Hi Ignis,
              Did you solve your problem? I have the same error on startup (though mine doesn't disappear as yours did) and I know the heater rods in the heat roll are on.
              • Ignis
                • Aug 2010
                • 28
                Hi Gus, I did not solve the problem yet, I'll have to disassemble the fuser and check the thermistors then I'll see how it will work.
                So far, every time I turn on the machine I open the main handle so fuser stops heating, then close it, then machine warms up normally without error.
                • GusG
                  • 198
                  Tried the above and I get 10-387 instead (External Heat Roll Warm Up Fail)
                  • adriansto
                    • 2387
                    Ignis check your PM
                    • Ignis
                      • Aug 2010
                      • 28
                      The solution of this problem is that I replaced Heat roller. The problem was the new hot roller (dc12) that was not an original for the 2060 machine. I have advice from servicer to put hot roller of DC12 machine, but that one has a thinner wall and different properties of heat .. and it heats up too much and because of that sensor error occurs.
                      Solved.
                      • smallsdesignink
                        I have a 790 Phaser and am just getting the same code 010-357 does anyone know how to fix the issue this is my main printer that I do a lot of charity work with.
                        Thanks,
                        Aaron
