Phaser 6180mfp Transfer Belt Reset ?
  • mrfuser
    • 1626
    Does anyone know what it is the needs to be reset on the transfer belt for a 6180? Is is a chip or a fuse? Seems a shame to fill the dumpsters with these things when the quality is fine.
    Thanks all!
    Kelly
  • hmartinp
    • Feb 2019
    • 9
    Re: Phaser 6180mfp Transfer Belt Reset ?
    I bought a used belt because I dropped a cart on my existing one and punched a hole in it. The used one immediately said "REPLACE", so guess I was bilked. So I took the 4 Philips screws from the damaged one and found a small circuit board removeable, so took it out to save for later. So when the used replacement dies completely I plan to replace the board with the one I scavenged...wish me luck.
    • rockdude
      • Feb 2011
      • 257
      Not sure myself (Might be a Pico fuse).
      But here is the replacement board from item inc. 675K47088-CHIP
      Good luck
      • hmartinp
        • Feb 2019
        • 9
        Good luck
        This looks just like the one I took out! I see it here for $35 (chip is on the bottom).... 675K47088-CHIP - Xerox 6180 Transfer Belt Chip Item Inc.
        • hmartinp
          • Feb 2019
          • 9
          So when my transfer belt quits I will remove the 4 screws and replace this board I salvaged from the torn transfer belt unit. Of course I assume there is a limit set perhaps due to quality of output, so will see if that is compromised by the extended life.
          • tuey
            • Apr 2014
            • 120
            while you have it apart make sure you completely clean out waste toner box. tuey
            • hmartinp
              • Feb 2019
              • 9
              Does the waste toner box play a role in the message to REPLACE?
              When it arrived there was toner all over it and I had to clean it up. So perhaps it dumped some in transit....will see.
              • tuey
                • Apr 2014
                • 120
                it's the chip only, if you change and dont clean waste box it will shortly oveflow with no message and make a nice mess. i know from experience.
                • hmartinp
                  • Feb 2019
                  • 9
                  Any idea if changing the chip and using the rest the same whether the belt itself is near toast???? Seems if they set at 100,000 copies there is some expectation??
