xerox workcentre 232
  • vespa geoff
    • May 2009
    • 37
    hi, going to look at one of these tomorrow . fault is producing dark copies when using adf seems to be ok from glass
    dont know xerox machines any pointers welcome.
  • adriansto
    • 2392
    Re: xerox workcentre 232
    May be very simple task to clean the mirrors from scanner assy. or a major defect of CCD board. In the last case need to change scanner assy or call a xerox tech to change CCD PWB and do proper aligniament and calibration.
    • bojans
      • 1313
      I believe cleaning mirrors will solve your problem.
      • Simons
        • Jun 2008
        • 490
        Can anyone give me advice about putting one of these on contract? I usually dont work on these, so they are new to me. Knowing the risks do you think I would have big problems with it?
        • bojans
          • 1313
          Very reliable machines from my point of view. I just like them. It has Drum and Fuser modules. Easy to change. Maybe you sometimes have to reload Network Controller software and clean the optics, vacuum some spilled toner, that's almost all.
          I recommend.
          Cheers
