Xerox 5632 Drum Stuck In
  • mrfuser
    • 1617
    Anyone ever seen the drum get stuck in the machine. Machine works fine, just can't remove drum to replace it. All levers work fine, removed fuser and dv unit and still won't pull out.
    Any ideas?
    Kelly
  • mrfuser
    • 1617
    Re: Xerox 5632 Drum Stuck In
    Okay, put a flat head screwdriver to front of drum unit between machine and drum and POP out it came! Could not pull it out by hand with a lot of force! Very strange. Hope this helps someone someday!
    Kelly
