XeroX WC Pro 245
  • Tropix
    • Jul 2011
    • 45
    XeroX WC Pro 245
    I have a problem with xerox 245
    everything was ok and then just messages on the display incompatibile xero module and push back the fuser ?!??
    On Status tab : image count 0, Project end of life -2 days / same for Fuser
    no error code found
    I did the following:
    - Chk Wires
    - Chk Crum
    - Try other drum, fuser
    - Install new Software module! PL 3.10 #8
    - Replace PWB with main motor
    but no luck
    don't know what to do next
    pls help
  • seansbar
    • Dec 2010
    • 198
    Re: XeroX WC Pro 245
    I had this on a 56xx machine. Had to replace the IOT PWB, and replace the Xero and fuser modules. I'm guessing CRUMs may do the trick.
    • livewire
      • Sep 2011
      • 608
      Hello Tropix,
      maybe you have a NVM corrupt.
      Try to reload NVM from MRD (Machine Resident Diskette).
      Success.
      • Tropix
        • Jul 2011
        • 45
        i try to reload NVM from MRD but not help
        I think it may be IOT pwb :/ but I'm not sure, can't purchase yet
        any help is appreciated
        Tnx
        • adriansto
          • 2392
          Voltage on yellow battery from software module is under 2 volts
          • Tropix
            • Jul 2011
            • 45
            No, i install new software module voltage is about 3V
            • adriansto
              • 2392
              Do you check that or do you think you may have 3 volts ?
              On older software module the battery voltage was ... ?
              • Tropix
                • Jul 2011
                • 45
                I checked before install, far as I remember 3.3 V
                • adriansto
                  • 2392
                  Check memory dram's in slots near software module.
                  In tools mode the service plan is A or B ?
                  Make the machine to be copier only. Enter service mode an do dc 132.
                  After that try again to restore nvm from MRD.
                  • Tropix
                    • Jul 2011
                    • 45
                    I do it but same problem
                    I try other memory from 5655 and same prob
                    my service plan is B
                    • nderimhoxha
                      NWM is corrupted Replase yellow batery and restore NVM from disc
