c2128 power supply needed
  • Gundyco
    • Aug 2025
    [Dead] c2128 power supply needed
    Our church has a 2005 C2128 that stopped working. Local Xerox company sent out a tech who said the power supply is bad. Also said that this machine is not made any longer and that he can not get a new power supply. Any comments or help would be appreciated.
  • azehnali
    • Nov 2009
    • 679
    Re: c2128 power supply needed
    sounds like he is trying to sell you a new machine
    is he sure its the power supply
    what is the exact problem
    and do you have a part # or know which power supply?
    • Gundyco
      The pastor is going to call the tech today and try and get a part number. Are parts availble for this machine?
      • adriansto
        • 2388
        There are many power supply for this machine.
        24 volts Low Voltage Power Supply has code = 105E13510.
        5 volts LVPS from 110 volts power outlet has code = 105E09821
        5 volts LVPS from 220 volts power outlet has code = 105E09831
        But I think this LVPS you can repair
        • Gundyco
          When turned on the display does not light up. The curcuit breaker that the main power cord plugs into does have power out the back black wire. The 3 power cords that come out do not have power. Those cords go to the computer down below, the copier above and the paper folder stapler on the right side. So what part number would that be and where would be the best place to check for one? Thanks
          • azehnali
            • Nov 2009
            • 679
            all the black cors are 110 vac
            do you hear any noise when you turn the copier on like the fans trays?
            • Gundyco
              I did not hear any noise at all.
              • adriansto
                • 2388
                Seems to be 24 v power supply.
                But you need service manual.
                • Gundyco
                  Do I need the service manual for dignostic or part numbers?
                  • adriansto
                    • 2388
                    In service manual you find wiring diagrams and the procedures for check the power supplies. Also find all partnumbers you need.
                    For service diagnose you'll need WCPS
                    • seximibabay07
                      • Mar 2013
                      • 59
                      Hello friend, do you have FIRMWARE and WPS Diagnostics tool for WorkCentre Pro C2128?
                      Best regards;
