Xerox print engine fault
  • JYB
    Hi everyone.
    I recently bought a Xerox Document center 440st.
    I have an error which tell "print engine fault"
    I try the solution of xerox support but there is no change.
    Can you help me.
    P.S
    I'm new in the forum and i didn't throw a presentetation topics.
    There is one ?
    Sorry for my poor english.
  • xcopytech
    • Aug 2006
    • 1794
    dc 440
    first you have to check which faul code you have.
    when machine show print engine fault, press key button, then #11.
    machine will inform you that can not enter in diagnostic and that firs have to disable print engine, and will ask you to confirm that.
    after that again enter key, #11 and enter in diagnostic mode, and check in fault history which code you have.
    Then write again to help you.
    best regards
    xcopytech@gmail.com
    • JYB
      The code is : U4-1
      • xcopytech
        • Aug 2006
        • 1794
        dc 440
        u4-1 is fuser under temperature
        check fuser lamps, thermistor, thermo fuse
        • JYB
          I'm sorry but i'm beginner.
          Can you tell me where it is locate ?
          Thanks.
          • xcopytech
            • Aug 2006
            • 1794
            dc 440st
            Look this is forum for copier techs.
            Not for end users.
            If you do not know machine parts you should call someone to fix your machine.
            So if you have problem with machine, call some copier tech form your region.
            Be honest; let us to get some money and to live.
            Best regards.
            • JYB
              I'm sorry and thanks a lot for your answer.
