Docucolor 12 Power Save on, No start up
  • jcontractor
    • Aug 2010
    • 247
    [Dead] Docucolor 12 Power Save on, No start up
    First, thanks to everybody for all the help in all posted failures in this forum.
    I have a DC 12 with power save green light on and no warming up.
    This is my first failure of this kind, I follow the Troubleshooting procedure (Power Save Green Ligth RAP) in the service manual.
    Also I follow 5+VDC RAP, because 5V wasn't present.
    And finally: no 5.1 V, No 5 V, No 12V present at LVPS Board.
    It have 110VAC at PCB input, Main LVPS fuse is good.
    No other check of the PCB was performed.
    As you experience, if I change the LVPS my problem will be solved?
    Or is any other troubleshooting to be performed before proceed to change this PCB?
    Any comment will be really appreciated.
  • JimmyB
    • Jun 2008
    • 77
    • jcontractor
      • Aug 2010
      • 247
      Re: Docucolor 12 Power Save on, No start up
      Yes, that's the pcb that doesn't have output voltage in my machine.
      Thanks a lot for your comment.
      Really appteciated.
      • S ali
        I have same problem where can we get this pcb should we buy from xerox or its available in electronics shops.
