Xerox Phaser 6200 "Engine Firmware Failure"
    • 23007
    I just got a service call on a Xerox Phaser 6200, with an "Engine Firmware Failure" message. Also doesn't recognize the drum cartridge any more.
    What is involved in re-loading the firmware (or replacing the firmware DIMM)? Is it even worth it?
  • just a tech
    • Jan 2007
    • 332
    do ya know what kinda code ya had with the "engine firmware failure".. the different codes are 70,71,72,73,74,77,78, and 79.. it appears though as if ya may be looking at a bad engine control board.. i've tried to copy, paste, and modify a couple of documents here for ya that may help.. good luck..hope it helps..
      • 23007
      This is great information. I'll try the firmware update, but I suspect it's futile. Thanks a lot.
      • ozstar
        Did the firmware or anything else work?
        rock
