Error Code 016-214
+ More Options
Posts
  • Alan Aya
    Error Code 016-214
    Hi pal,
    Having this 016-214 error code after doing some cleaning up and dismantle of FAX board. Is the error appear because of the FAX board has been taken out? if it is, then how do i reset it without installing the FAX Board? Need to deliver the machine on Monday for rental.
    Any help would be much appreciated.
    Thank you.
  • adriansto
    • 2383
    Re: Error Code 016-214
    It is a washing machine ?
    • Alan Aya
      Sorry, my mistake its Document Centre 286.
      • adriansto
        • 2383
        Put the fax board at his place.
        • jamesfoo
          Hi pal,
          Thank you.
          Hi Alan,
          I have the same problems with the 016-214 and wish to remove Fax card, too. I saw this post of yours since a while ago for DC286.
          Do you mind to share your solution with me?
          Thanks a million.
          • livewire
            • Sep 2011
            • 608
            Try this:
            You must log in as admin from UI.
            Locate the entry menu of Software options.
            Enter:
            ClearAllFlag
            Select:
            Reboot
            Very Important:
            This procedure will erase all the options that are machine have.
            You need codes to enable the options again.
            Their own risk.
            • jamesfoo
              Thanks livewire.
