5675 scanner fault with ledger on glass
  • mrfuser
    • 1621
    If client uses adf to feed ledger it works fine letter on glass works fine.
    if they place ledger on glass it goes into an error and makes them reboot before they can use machine again.
    Says scanner fault.
    Any ideas?
    Kelly
  • copymech
    • Sep 2011
    • 196
    There maybe a break in the scanner cable. Sometimes they break inside the insulation.
