WC4150 can't scan to email
  • e4704p2
    • Jun 2025
    email configs look good but no success-
    specifying known good SMTP server
    and known good email address and password
    SMTP authentication enabled
    any help you may give would be appreciated!
  • Milo Wilson
    • 502
    Re: WC4150 can't scan to email
    Upgrade or reload firmware on unit.
    • ZeusGT
      • 271
      OK, if your SMTP requires TLS or SSL layer encryption, your WC4150 will not be able to scan to email. There is a work around to this. Go to SMTP2go.com and sign up. You will be able to use your same email SMTP, but you will route through an SMTP server that doesn't require SSL.
      CompTia A+ Certified
      CompTia Net+ Certified
      CompTia Server+ Certified
      CompTia Project+ Certified
      OP Scanshare Certified
      • TheOwl
        • Nov 2008
        • 1732
        If the network is running an Exchange Server:
        http://www.copytechnet.com/forums/co...-exchange.html
