Fiery X12 - Stuck on Loading Screen
  • littly_kitty
    • Mar 2010
    • 34
    My Firery X12 is stuck on the "loading...." screen.I have tried holding down the fourth button to call up the menu to restore back up, but the menu will not appear.
    I have tried using Spinrite as detailed in this thread. In the past, that used to work. However, it's not working this time.
    I have read that I can solve my problem by putting a new harddrive in the Firery. I took an 80GB drive from an old PC and put it the Firery.When I did this, and held down the foruth button, the menu did appear.
    However, it doesn't matter which option I select, they all go to a blank screen.
    How can I reinstall the firery software on the new hard drive? (I have the installation discs).
    Incidentally, when I put the old harddrive in the firery, I can't get the menu to appear (when holding down the forth button). I'm not sure if that means anything.
  • hishnikys
    • Feb 2012
    • 6
    Re: Fiery X12 - Stuck on Loading Screen
    I beg your pardon for the translation, the translator was translating. I had this problem, replace the power supply and battery and now everything is OK
    • littly_kitty
      • Mar 2010
      • 34
      I don't understand.... I didn't think the firery had a battery.Does the new hard drive have to be formatted in a certain way?
      • davidj7
        • 1107
        just insert your CD1 at boot up and recycle power at the end of it and wait for your prompt to insert Cd 2 . simple
        a machine is only as good as your tech : source:screwtape ; the scary one
        • littly_kitty
          • Mar 2010
          • 34
          I try that but when I get to the installation screen and select to install from disc, the screen goes blank and nothing happens.Does the new hard drive have to be in a certain format?
          • davidj7
            • 1107
            i dont think so . I haven't done it with a fresh hard disk . You could try formatting or your disk is damaged.edit: how long did u wait for it to complete the re install ?
            • littly_kitty
              • Mar 2010
              • 34
              HiWith the new hard drive, I left it on all day, but nothing happened.With the old (Original) hard drive: I can't seem to get to the installation menu. I've taken great care to make sure that I have held down the forth button carefully, but it just gets stuck on "loading...".
              • davidj7
                • 1107
                i think my re install took about 45 minutes. well obviously somethings wrong here . Do you have another copy of the installation disks ? make sure the jumper settings matches that of the old HDD.
                • bojans
                  • 1313
                  You can attach monitor to Fiery and see what happens.
                  • littly_kitty
                    • Mar 2010
                    • 34
                    When I attach the monitor to the fiery using the old hard drive (ie. the one that came with it), I get the following error messages:
                    "Non-System disk or Disk error
                    Replace and press any key when ready
                    Boot Failure
                    Reboot and select proper boot device
                    Or Insert Boot Media in Selected boot device
                    Press any key when ready"
                    How do I select the boot device?
                    The disc is in the CD-Rom Drive.
                    I've tried holding down the forth button, but nothing happens.
                    • davidj7
                      • 1107
                      you have no operating system on your hard drive. you need to install .I think your source disk is damaged
                      • littly_kitty
                        • Mar 2010
                        • 34
                        Hi
                        I think the problem is with Cd-ROM Drive. It doesn't open without using a paper clip. Even if I open it with a paper clip, the firery wont recognise the disc.
                        Although the light on the CD-ROM drive is continually flashing.
                        Can I replace it with any IDE CD-ROM drive or do I need a special one?
                        • bojans
                          • 1313
                          You can use any CD ROM you have.As far as i remember you should format hdd ih FAT filesystem.
                          • littly_kitty
                            • Mar 2010
                            • 34
                            Would a DVD -Rom drive work, or are they too new for the ripper.
                            Thanks for all the continued help. I really appreciate it.
                            • bojans
                              • 1313
                              I believe it would work. Try you can't loose anything.
