Xerox WCP 245 controler died
  • Tinochka
    • Jul 2012
    • 127
    #16
    Re: Xerox WCP 245 controler died
    Originally posted by bojans
    Hi Tinochka,
    As I said before had this error: UNDI INITIALIZE Failure but can't remember how did I resolve it. But I have bought new laptop that time, so you could try with other laptop. Doesn't have to be true but you can try that option.
    I tried to connect my laptop with Xerox dc555 and everything works perfect. Laptop and cables works ok. I checked them.
    • Tinochka
      • Jul 2012
      • 127
      #17
      Originally posted by adriansto
      What is pws laptop ip address and subnet mask ?
      Do you really checked the crossover cable ?
      What IP on laptop should I setup?
      • livewire
        • Sep 2011
        • 608
        #18
        Hi,
        on PWS
        IP: 192.168.0.2
        Subnet: 255.255.255.0
        • Tinochka
          • Jul 2012
          • 127
          #19
          Originally posted by livewire
          Hi,
          on PWS
          IP: 192.168.0.2
          Tried this IP, but the same situation.
          • shugnite
            • Sep 2011
            • 13
            #20
            Hi,
            I've the same problem you had and now my controller is about to be rendered useless.
            Did you ever find a solution?
            • adriansto
              • 2388
              #21
              Do you have the altboot tool?
              Sent from my V3-E using Tapatalk
