Xerox obviously changed the method of cleaning the charge roller on the YMC drums when the made the 700... The 250 style has the foam, or more recently, the soft brush, which gets pushed down onto the charge roller every so often to clean it. The 700 has a foam roller which looks to be in permanent rotating contact.
Question for those who have high volume 700's... Does this new method help the drums last longer? Or at least last all the way to 0% without failing early? The 250 style seem to often get just caked in white powder (even when the pusher fingers are working just fine) pretty quickly, and eventually this affects the print quality. Do the 700 drums hold up better?
Shame they're not interchangeable, but it would be good to know for the future, in case I get a 700.
Thanks!
Thanks!
