Workcentre pro 65 pull out fuser
  • mrfuser
    • 1622
    Hi all
    i have a client with a Wcpro 65 that tells us to pull out fuser and firmly push back in. We put another fuser in and same result. Error code is fuser not warming up.
    any ideas?
    kelly
  • Piper
    • Apr 2011
    • 77
    Re: Workcentre pro 65 pull out fuser
    I had same problem on the Document Centre 470. I replaced the FLICKER PWB and it was ok.
    The Flicker in the DC 470 is located at the rear of machine and directly in line with fuser.
    Im not sure if the Wcp 65 has a flicker pwb, but check where the fuser connects to.
    • Scarecrow
      • Oct 2010
      • 234
      Originally posted by mrfuser
      Hi all
      any ideas?
      kelly
      There is a whiteish cream colored, underrated relay in the box where the power cord enters the machine. The pitted contacts can be filed. Try not to bend the flimsy contact leaf spring.
      • CopierTechofOmens
        Agitating Artificer
        • 268
        Ac Distribution Panel. North American version (101K40492) Euro. (101K42660)
        Flicker is used mostly in Europe.
        sigpic
